ACI Brownfield to multi-site
brlehigh
Good day,
I have an existing production fabric and I'm spinning up a Greenfield DR fabric.  I am worried about potential service impact(s) to my production fabric when adding it to multi-site.
The "tl;dr" of my post is: Is there a service impact when I initially add my fabric to Nexus Dashboard
Orchestrator and again when I enable Multi-site and apply the needed infra config from NDO?
I've read through several deployment documents but I found the following bullet-point in Cisco ACI Multi-Site Architecture White Paper :
When a site is added to a Multi-Site domain, the BGP RID is modified on the spines that are configured as BGP speakers. This may cause the re-establishment of intra-fabric VPNv4 adjacencies between the spines (configured as RR for the fabric) and the leaf nodes, with consequent impact on north-south communications. Therefore, it is recommended to perform the addition of the site to the Multi-Site domain during a maintenance window.
My fabric is configured as network centric with the majority of the gateways residing outside the fabric.  Will there be a service impact to any layer 2 traffic in/out of the fabric or is this above warning just for layer 3 traffic (l3out)?
My Greenfield / DR fabric is already up and added to NDO with multi-site enabled and have it connected to the ISN.  I haven't done much beyond day-0 config on the new fabric, with the intent of stretching the tenant and a few dozen EPGs from the prod fabric.
Are there any other caveats that I should be ware of before adding a production fabric to NDO / Multi-site?
brlehigh
I'll go ahead and reply to my own post to close the loop.
I enabled multi-site on my production fabric this morning.  I did not experience any service disruption when adding the site to Nexus Dashboard or when enabling "Managed".
When I configured the infra for this site via Nexus Dashboard Orchestrator and deployed the configuration, I did see the BGP processes bounce on my prod fabric, however, I did not notice a service disruption to any of my traffic.
Again, we do not do a ton of layer 3 north-south traffic from this fabric, so it might have been more impactful had this not been the case.  I did have pings going throughout the window and did not experience any loss.
With that said, I would still recommend performing this process during a maintenance window.
brlehigh
With apologies for resurrecting an old thread...
My experience was with 2 fabrics, one version 5.2(6e) and one version 6.0(9e) both of which were using VPC L3Outs. When I added the sites to Nexus Dashboard there was no service disruption for the 5.2(6e) fabric, but North-South traffic to the 6.0(9e) fabric was disrupted until I deleted and recreated the L3Outs. Traffic within the fabric was unaffected (at least, a Nutanix cluster which had been prestaged and had its L3 gateways within the fabric didn't report any disruption)
My best guess (not possible to confirm before I needed to bring service back up) was related to the L3Outs being created using the "old-style" switch selectors and interface selectors before the affected fabric was upgraded. When they were recreated I used the "new-style" automatically created selectors.
Deploying the Multi-Site configuration didn't cause any service disruption to either fabric for me, and similarly I saw the BGP process bounce very briefly.
I'd second the recommendation to do this during a maintenance window.
