ACI Deployment - Post Install Verification and Testing
navydivervet
Is there existing/recommended documentation on verifying and testing, after an ACI deployment? I know this is a broad question, but was just looking for some good resources or methods...
stcorry
I'm not sure if there is any publicly available document that details this kind of testing, usually it is pretty specific to the implementation and focuses on the Endpoints and applications that are deployed in the environment.
This document might help you check into if best practices are being used:
https://unofficialaciguide.com/2018/11/29/aci-best-practice-configurations/
Checking Faults is a great to ensure that everything has deployed ok.
And if you mean after a change or upgrade, the ACI Appcenter App StateChangeChecker is a great tool to check the state of objects in the fabric before and after the change.
https://dcappcenter.cisco.com/statechangechecker-2-2-1n.html
Cisco Official guides are recommended. and also you can use whtie papers
for more detials
