ACI Device Administration using ISE
snarayanaraju
Level 4
Level 4
Hello Experts - Looking for your help before i go configuring ACI to integrate with ISE for Role Based Access (RABC) and Authenticate ACI login using ISE
I read documents and understood that ACI APIC and Leaf/Spine Switches have to be added to ISE in Network Devices (NAD).  I am pretty sure I can configure APIC as Network Device is ISE by entering the TACACS Password which i configured in APIC.
Question: When adding Leaf/Spine Switches in ISE as Network Devices, what password I have to enter in ISE ? Should it be the one I configured for APIC?
regards,Sairam
julian.bendix
Hi!
Haven't tried this before to be honest (will try it in a lab troughout the next week :) )
But so far.. if I read the following:
https://community.cisco.com/t5/data-center-documents/configuring-tacacs-authentication-to-aci-fabric-with-cisco-acs/ta-p/3228328
It seems that the same shared secret as configured on the APIC will be used for the Switches as well.
Hope that helps, otherwise I can update you once I have labbed this scenario.
Best regards
Juls
