09-13-2018 09:43 AM - edited 03-01-2019 05:39 AM
I have a mulipod network. I have created a BD/EPG with encapsulation 2101. which has endpoints in both POD1 and POD2. I am facing connectivity issue between the endpoints in POD1 and POD2.
Do I need to configure anything specially in multipod network to establish the connectivity between endpoints part of different POD's.
I have read that dynamic tunell would be formed between leaf's part of different POD's.
09-13-2018 05:38 PM
09-13-2018 09:23 PM
09-13-2018 09:26 PM
09-24-2018 10:09 PM
09-24-2018 11:21 PM
Click on Tenants>>>User Tenant>>>.Networking>>>>Bridge Domains
Once you do that you would see multicast addresses against each BD. Make a note of the multicast address on your BD. Now on your IPN's check o/p of command "show ip mroute". Do you see that multicast address reflected in that table? If not then you might have an issue with the setup on IPN's with ACI.
In short there can be whole lot's of issues that might prevent you from pinging between two segments. Also, can you paste a diagram of your setup might be easy to visualise then..
09-25-2018 05:15 AM
09-25-2018 07:32 PM
Here is the o/p from my IPN:
(*, 239.255.255.240), 4w6d/00:03:07, RP 200.200.200.204, flags: BC
Bidir-Upstream: Loopback5592, RPF nbr 200.200.200.204
Outgoing interface list:
Loopback5592, Bidir-Upstream/Sparse, 1w6d/stopped
GigabitEthernet0/0/2, Forward/Sparse, 1w6d/00:03:07
Te0/0/0.4, Forward/Sparse, 1w6d/00:02:48
Could you please share information of all 4 IPN's. I would like to see o/p of interface configs from where you are picking up RP.
Saurav
09-25-2018 08:45 PM
01-08-2019 05:38 AM
Did you get to the bottom of this issue? I'm curious to what resolved the issue.
