04-25-2020 02:21 PM
what are best practices for ACI F5 integration unmanaged mode? will ACI push EPGs to F5?
04-26-2020 02:14 PM
Hi @gavinhans,
Unmanaged mode, also known as network policy mode means that APIC only configures the network portion of the service graph, and doesn't push configurations to the L4-L7 device.
It is hard to say "these are the best practices" since it all depends on the topology, desired flow, requirements etc.
I would suggest to have a look over the whitepapers:
There is also a F5 BIG-IP app which can be installed on your APIC: https://dcappcenter.cisco.com/f5-aci-servicecenter-3-2-7f-2-3-522.html
Hope it helps,
Sergiu
04-27-2020 11:48 AM
Best and easy way is as below. It assumes ACI is gateway for all EPG.
Create F5 LTM in two arm mode
The advantage of this design is that you can use any subnet as VIP Pool and just route it to LTM external next hop IP.
with regards,
Prasad
04-27-2020 07:37 PM
Thank you Prasad.
why this method is preferred over un-managed service graph?
