10-23-2017 11:11 PM - edited 03-01-2019 05:21 AM
Hello
Can I use a tag and an untagged van on the same EPG?
Is this configuration supported?
Ex...
EPG-A > Static Port: tag vlan100
EPG-A > Static Port: untagged vlan100
If not, how do I manage the tag and the untagged vlan?
I'm looking for reference document.
Best Regards,
Yoshi
Solved! Go to Solution.
10-23-2017 11:20 PM - edited 10-23-2017 11:21 PM
Hi Yoshi,
I would recommend that you check out the link below.
JW
Hi Yoshi,
JW
10-23-2017 11:43 PM
Thanks Jason,
I solved the problem.
Best regards,
Yoshi
06-07-2018 10:24 AM
hello yoshi, could you share how did you solved the problem, we have the same issuee
we will appreciate it
thanks
