07-30-2018 09:31 PM - edited 03-01-2019 05:36 AM
Hello guys,
I am having this problem:
When I tried to jump from 1 of my APIC to switches located on Pod 2 in a multipod deployment I can't connect to them via ssh.
APIC3#ssh SPINE-2201
ssh: connect to host spine-2201 port 22: No route to host
Spine 2201 has 10.2.176.64 IP addrees, after checking routes from the APIC to the subnet 10.2.0.0/16 on vrf overlay-1, there is the route:
SPINE-2101# show ip ospf route vrf overlay-1
OSPF Process ID default VRF overlay-1, Routing Table
(D) denotes route is directly attached (R) denotes route is in RIB
10.1.0.0/16 (type-2) area backbone
via 10.20.1.2/Eth1/63.63 , cost 20 distance 110
via 10.20.1.6/Eth1/64.64 , cost 20 distance 110
10.1.0.1/32 (type-2) area backbone
10.1.0.33/32 (type-2) area backbone
10.1.0.34/32 (type-2) area backbone
10.1.0.35/32 (type-2) area backbone
10.1.152.65/32 (intra) area backbone
via 10.20.1.2/Eth1/63.63 , cost 3 distance 110
via 10.20.1.6/Eth1/64.64 , cost 3 distance 110
10.1.152.66/32 (intra)(D) area backbone
via 10.1.152.66/lo0* , cost 1 distance 110
10.2.0.0/16 (type-2)(R) area backbone
via 10.20.1.2/Eth1/63.63 , cost 65535 distance 110
via 10.20.1.6/Eth1/64.64 , cost 65535 distance 110
10.2.0.33/32 (type-2)(R) area backbone
10.2.0.34/32 (type-2)(R) area backbone
10.2.0.35/32 (type-2)(R) area backbone
10.2.176.64/32 (intra)(R) area backbone
via 10.20.1.2/Eth1/63.63 , cost 5 distance 110
via 10.20.1.6/Eth1/64.64 , cost 5 distance 110
10.2.176.65/32 (intra)(R) area backbone
10.20.1.0/30 (intra)(D) area backbone
via 10.20.1.0/Eth1/63.63* , cost 1 distance 110
10.20.1.4/30 (intra)(D) area backbone
via 10.20.1.4/Eth1/64.64* , cost 1 distance 110
10.20.1.8/30 (intra)(R) area backbone
via 10.20.1.2/Eth1/63.63 , cost 2 distance 110
10.20.1.12/30 (intra)(R) area backbone
via 10.20.1.6/Eth1/64.64 , cost 2 distance 110
10.20.1.16/30 (intra)(R) area backbone
10.20.2.0/30 (intra)(R) area backbone
via 10.20.1.2/Eth1/63.63 , cost 6 distance 110
10.20.2.4/30 (intra)(R) area backbone
via 10.20.1.6/Eth1/64.64 , cost 6 distance 110
10.20.2.8/30 (intra)(R) area backbone
10.20.2.12/30 (intra)(R) area backbone
10.20.2.16/30 (intra)(R) area backbone
via 10.20.1.2/Eth1/63.63 , cost 9 distance 110
via 10.20.1.6/Eth1/64.64 , cost 9 distance 110
10.200.0.0/30 (intra)(R) area backbone
10.200.0.12/30 (intra)(R) area backbone
11.11.11.1/32 (type-2) area backbone
12.1.1.0/29 (intra)(R) area backbone
12.1.1.0/30 (intra)(R) area backbone
22.22.22.2/32 (type-2)(R) area backbone
111.111.111.1/32 (intra)(D) area backbone
via 111.111.111.1/lo11* , cost 1 distance 110
111.111.111.2/32 (intra) area backbone
222.222.222.1/32 (intra)(R) area backbone
222.222.222.2/32 (intra)(R) area backbone
Any ideas?
Solved! Go to Solution.
08-01-2018 02:12 PM - edited 08-01-2018 02:13 PM
try using "attach" command, rather than SSH
if you have to use SSH, try
ssh <device> -b <APIC IP>
