ACI Multipod - Problems discovering spines in Pod2
Luis Perez
I have my first pod configured and i think the configurations in the IPN and the two wizards from APIC covered but actually the pod2 spines doesnt appear in the fabric membership not registered nodes.
Which steps do you recommend to review this??
Actually i have ip connectivity and OSPF neighboship between SpinePod1 - IPNpod1 - IPNpod2
Also multicast routes appear to be working fine
In APIC actually i have three faults related with tunnel interfaces showing destination unreachable, that destinations refer to TEP Pool POD2 address i think not yet assigend before to register the Pod2 spines
Thanks in advance
Luis
Marcel Zehnder
Hi Luis
Sounds like there are some configuration issues (within ACI and/or your IPN) - check out the troubleshooting book (starting at page 36):
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/aci/apic/sw/4-x/troubleshooting/Cisco_TroubleshootingApplicationCentricInfrastructureSecondEdition.pdf
