ACI plugin vcenter not compatible
Networker0
We are trying to install the ACI plugin on vcenter 6.7 (for AVE) using a centos 7 VM but after deploying it In vcenter, it shows up that the plugin is incompatible.
this error is shown: "The plug-in only supports the vSphere Web Client (Flash)."
We are using the latest version of the plugin (5.2.2).
Is there any solution?
Thnx
Robert Burns
You're likely using the wrong plugin. You need the HTML plugin:.
https://software.cisco.com/download/home/285968390/type/286326595/release/1.0.4
Robert
Robert Burns
Robert
