ACI Remote Leaf 10G only Fabric Interface on N9K-C93180YC-FX
Thomas May
Hello all,
we want to deploy a pair of remote leafs of N9K-C93180YC-FX. But there are only 4x 1G to the IPN. Because of this we want to use the Ports 47 and 48 on both leafs as fabric/uplink ports. Is this supported? Or do I have to use the 100G ports with adapters?
If it is supported I wonderd how the initial discovery works. Because as default only the 100G ports are fabric/uplinks ports. Is there a way to configure the 10/25 ports as uplink before discovery? (via console?)
Thanks already.
YanL
should work with a CVR adapter and 1G SFP in ports 49-54
