03-04-2015 08:46 AM - edited 03-01-2019 04:48 AM
So I downloaded the ACI Simulator. It´s been available to partners since 10th of Feb.2015. Here is the link if you havent found it yet.
Does anyone know the limitations, can I install it in a home environment? I´ve seen it requires the UCS C220 M3...
Solved! Go to Solution.
03-06-2015 06:36 AM
Hi Mateja,
I work for Cisco in our ACI solutions support team (TAC). In the lab I have attempted to install the ISO on a UCS C220-M3 that was not properly programmed with the correct PID and the simulator software did not work. Errors in the logs were:
6698||14-12-10 10:06:53.485+00:00||proc_app||DBG4||||Simulator is running in baremetal, performing PID Check||../common/src/ifcutils/ifc_pid_check.cc||37 16698||14-12-10 10:06:53.489+00:00||proc_app||ERROR||||Failed to find matching system-product-name||../common/src/ifcutils/ifc_pid_check.cc||97 16698||14-12-10 10:06:53.490+00:00||log||CRIT||||UNCONDITIONAL ASSERT (NOT REACHED!) (0) failed @ ../svc/appliancedirector/src/gen/ifc/mains/./Svc.c c:36 ||../common/src/osiris/./core/log/LegacyApi.cc||23 2 -- Traceback -- [0] /mgmt/usr/lib64/libosiris.so : core_log::TracePrinter::~TracePrinter()+0x2de [0x7fd3ca75f774] [1] /mgmt/usr/lib64/libosiris.so : core_log::logPrintfRaw(char const*)+0x20b [0x7fd3ca76264b] [2] /mgmt/usr/lib64/libosiris.so : error::assert_failed(char const*, ...)+0xf4 [0x7fd3ca74f044] [3] /lib64/libc.so.6 : exit+0xe2 [0x7fd3c2c95de2] [4] /mgmt/usr/lib64/libifcutils.so : ifcutils::BiosUtils::ApicPidCheck(bool)+0x20e6 [0x7fd3c379c766] [5] /mgmt/usr/lib64/libsvc_ifc_appliancedirector.so : ifc_appliancedirector::Svc::init(int, char**, unsigned short)+0x9f0 [0x7fd3cb319460] [6] svc_ifc_appliancedirector.bin : main+0xde [0x7fd3cb7f0a9e] [7] /lib64/libc.so.6 : __libc_start_main+0xfd [0x7fd3c2c7ecdd] [8] svc_ifc_appliancedirector.bin : +0x78e9 [0x7fd3cb7f08e9]
Again - you *MUST* use a server sold with the PID APIC-SIM-S. Bare metal C220-M3 servers are not supported. Feel free to send me a private message of who at Cisco said it could be deployed on "UCS" and I will follow-up to make sure the hardware requirements are clear.
Mike
03-10-2015 08:01 AM
The iso is used to upgrade the APIC Sim. Yes, it comes pre-installed on the HW, but we do occasionally upgrade the APIC Sim software.
Robert
03-04-2015 12:30 PM
The ACI simulator is a hardware/software based product with it's own PID, i.e. you will not have success by installing this into anything but the APIC-SIM-S product.
See table 3 here:
The release notes cover the limitations:
Mike
Edit: Make URL's actually link to the pages.
03-06-2015 03:04 AM
Not really, because now you can download the ISO of this simulator and yes, you need to deploy it on the UCS as an ISO... 😞 It´s the answer I got from Cisco.
I am not 100% sure on the hardware requirements or some limitation but I am researching it for you. Currently, i can provide you these links to get started:
Release notes for ACI 1.0(2j) Simulator image: http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/release/notes/aci_simulator102_rn.html
Installing the ACI Simulator Software: http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/simulator/getting-started/b_ACI_Simulator_Getting_Started_Guide/b_APIC_Simulator_Getting_Started_Guide_chapter_010.html
Simulator Getting Started Guide:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/simulator/getting-started/b_ACI_Simulator_Getting_Started_Guide/b_APIC_Simulator_Getting_Started_Guide_preface_00.html
Hope this helps 🙂
03-06-2015 06:36 AM
Hi Mateja,
Mike
03-10-2015 05:30 AM
Thanks Mike.
I´ll send you a PM with the details.
[Update: Seems that I can´t send you a PM, could you send me one and I´ll reply with the info you asked?]
On the other hand - I don´t really get why is there even ACI .iso Simulator available for partner download if we can´t use it... because if we get the APIC-SIM-S, we don´t even need the .iso.
Cheers
03-10-2015 08:01 AM
Robert
03-10-2015 08:09 AM
Ok, now it makes sense... thanks for the clarification.
Too bad... I was really looking forward to testing the OpenStack integration without asking for the 15k additional investment from the financial guys 🙂
03-10-2015 08:48 AM
There is an ACI & Openstack Integration demo lab on dCloud. Ask your local account team - they should be able to give you access so you can run through the Openstack integration and get a sense how to implement & use it.
Robert
05-30-2017 05:28 AM
I've stumbled upon this topic while trying to find out more about ACI simulator. Are there any changes in this respect? Last message is 2 years ago, maybe now it is possible to install it on any server. Or is it still tightly coupled with server?
Thanks!
Best regards,
Danil
05-30-2017 05:54 AM
Daniel,
The Cisco ACI Simulator is a physical appliance that provides a simulated Cisco ACI environment.
You can find more information in the like provided for the Data Sheet for the Cisco ACI APIC Simulator.
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/application-centric-infrastructure-simulator/datasheet-c78-733252.html
Cheers!
T.
03-05-2015 08:16 AM
If anyone else is facing the similar problem, note that I got am email from Cisco stating the following:
You have to run the simulator on the UCS hardware.
Not what I was hoping for, but... oh well, we might just be getting an UCS for our demo center...
03-05-2015 12:05 PM
Not just UCS hardware which could potentially mean many different products. The requirement is the following product: APIC-SIM-S
