I am in the process of building an ACI simulator in our lab environment.
The ACI simulator VM is deployed on an ESXi host which is connected to an actual physical ACI fabric
During the initial setup, I configured IPv6 OOB mgmt IP address on the ACI simulator VM. However I was not able to ping this IPv6 address from the directly connected leaf switch.
Then, I configured IPv4 as well as IPv6, and I am able to ping the IPv4 OOB mgmt address and also able to learn it as endpoint but not able to ping ipv6 address.
Its is required that the ACI simulator OOB mgmt should be reachable over IPv6 address.
Are there any known issues or any special settings to be done for making IPv6 OOB mgmt address to work.
on the BD I have enabled the ND RA prefix control flag.
Thank You!
Nilesh
