APIC 3 of cluster stuck at "Setting up network configuration"
KVS7
So I don't know how this happened but despite all leaf/spines showing "Active" via acidiag fnvread, the third APIC is stuck at "Setting up network configuration". Rebooting just takes me right back to this screen again. avread alone shows that the cluster size is 3 but 2 APICs are active. Otherwise all 2 APICs + nodes show Healthy.
The third APIC is plugged in with CIMC access but the two uplinks to the leaf switches are down. The leaf says "link not connected" but that's only because the APIC has not fully booted up.
How do I recover when every time I reboot, the APIC goes straight to setting up network configuration... ?
Cluster fault says F1410. The usual, cluster size is 3, actual size is 2. No contenders blah blah. But this is because the APIC is stuck and won't seem to pass go. Image attached. Basically, I suspect when the cluster was created, the third one never fully finished setting up and nobody noticed.
2 Accepted Solutions
KVS7
I was able to pull the software after creating an HTTP web server virtual directory. Seems like the only option.
Even a fresh install didn't fix this particular issue. Management eth1-1 never comes up. We got an RMA
KVS7
For more insight, the cluster never fully formed. Two APICs are healthy but the third one never made it. So there's nothing to decommission in the GUI. Should I just reinstall the APIC software from the CIMC?
KVS7
Nobody has ever done a clean install of the APIC? Must be nice.
KVS7
