apic re-installation failed
eckoshi48155
Hi All,
new beginner here, since last time the TPM issue was solve so my work could continue on, but after that i have facing another issue that showing as below,
may i ask is there any pre-configuration relate the BIOS or thr RAID adapter controller?
07:22:07 E: 2020/04/18 07:22:07 info extracting duration=23m25.112915997s
07:22:08 O: sending incremental file list
07:22:08 O: boot-hook
07:22:08 O: post-install-hook
07:22:08 O: product
07:22:08 O:
07:22:08 O: sent 10652 bytes received 72 bytes 21448.00 bytes/sec
07:22:08 O: total size is 10438 speedup is 0.97
07:22:08 O: ./
07:22:08 O: fwrepos -> /firmware/fwrepos
07:22:08 O:
07:22:08 O: sent 66 bytes received 18 bytes 168.00 bytes/sec
07:22:08 O: total size is 17 speedup is 0.20
07:22:08 O: ./
07:22:08 O:
07:22:08 O: sent 29 bytes received 15 bytes 88.00 bytes/sec
07:22:08 O: total size is 0 speedup is 0.00
07:22:08 E: 2020/04/18 07:22:08 warn could not mount lv securedata in copyFilesToLV, ignoring
07:22:08 O: ./
07:22:08 O: crash/
07:22:08 O:
07:22:08 O: sent 54 bytes received 19 bytes 146.00 bytes/sec
07:22:08 O: ./
07:22:08 O:
07:22:08 O: ./
07:22:08 O: fwrepos/
07:22:08 O: fwrepos/fwrepo.Local/
07:22:08 O: fwrepos/fwrepo.Local/aci-catalog-dk9-default.bin
07:22:08 O:
07:22:08 O: sent 74717 bytes received 42 bytes 149518.00 bytes/sec
07:22:08 O: total size is 74550 speedup is 1.00
07:22:09 E: 2020/04/18 07:22:09 info setting up newHash=757742f3f5103cef7b97c770a90e76f6e2b9995ecf272a54dde64d9d5528c5a5 serviceType=_ target=boot
07:22:09 E: 2020/04/18 07:22:09 info No setup to do for servicetype _ newHash=757742f3f5103cef7b97c770a90e76f6e2b9995ecf272a54dde64d9d5528c5a5 serviceType=_ target=boot
07:22:09 E: 2020/04/18 07:22:09 info setting up duration=10.982µs newHash=757742f3f5103cef7b97c770a90e76f6e2b9995ecf272a54dde64d9d5528c5a5 serviceType=_ target=boot
07:22:09 O: boot:4.0.1h-d691300 has no pre-update hook
07:22:16 E: Error: device or resource busy
07:22:16 E: failed mounting boot for rsync
07:22:16 E: golang.cisco.com/atom/atomix.(*Atomix).GrubDoSetup
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/update.go:103
07:22:16 E: golang.cisco.com/atom/atomix.(*Atomix).GrubSetup
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/update.go:262
07:22:16 E: golang.cisco.com/atom/atomix.(*Atomix).SetHead
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/atomix.go:228
07:22:16 E: golang.cisco.com/atom/atomix.(*Atomix).Install
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/install.go:248
07:22:16 E: main.doInstall
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/cli/install.go:67
07:22:16 E: golang.cisco.com/atom/atomix/vendor/github.com/urfave/cli.HandleAction
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/vendor/github.com/urfave/cli/app.go:501
07:22:16 E: golang.cisco.com/atom/atomix/vendor/github.com/urfave/cli.Command.Run
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/vendor/github.com/urfave/cli/command.go:165
07:22:16 E: golang.cisco.com/atom/atomix/vendor/github.com/urfave/cli.(*App).Run
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/vendor/github.com/urfave/cli/app.go:259
07:22:16 E: main.main
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/cli/main.go:61
07:22:16 E: runtime.main
07:22:16 E: /usr/lib/go-1.10/src/runtime/proc.go:198
07:22:16 E: runtime.goexit
07:22:16 E: /usr/lib/go-1.10/src/runtime/asm_amd64.s:2361
07:22:16 E: Failed updating grub
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/atomix.go:230
07:22:16 E: Failed activating layer boot
07:22:16 E: /root/go/src/golang.cisco.com/atom/atomix/install.go:249
07:22:16 E: + cleanup
07:22:16 E: + rm -f /tmp/rRfN2tNg
07:22:16 E: + rm -f /tmp/lkf
Gaurav Gambhir
I have seen something similar in past, you should try to rebuilt the RIAD. You can follow the following document.
https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/application-policy-infrastructure-controller-apic/215166-apic-ssd-replacement.html
Gaurav Gambhir
