APIC standby did not upgrade automatically
williammanurung
Hi All,
I believe based on data sheet, APIC standby will upgrade automatically after APIC active upgraded, but in fact I have experience with two customer that have APIC active and APIC standby. APIC standby will not automatically upgrade after APIC active finish upgraded .
So, any of you have same experience? then how can we upgrade APIC standby?
Thank you.
ecsnnsls
Are you able to view the status of the standby APIC using the "show controller command?
Can you let us know the software version of the APIC?
Sergiu.Daniluk
Hi @williammanurung
How and when, after the cluster upgrade, did you checked if the standby APIC was upgraded?
Cheers,
Sergiu
Hi All,
Apologies, yes APIC standby automatically upgraded after some time.
Happy to hear that standby APIC upgrade works as expected ^_^
