Changing APIC
I have a cluster of 3 APICs (APIC-CLUSTER-M2).
I want to change the 3 medium APICs to the large APICS (APIC-CLUSTER-L2)
Can I add the new APICs to the cluster and then remove the old ones? or is there another way to change the APICs without affecting the network.
russhe
Hey Ziad,
I would recommend replacing the APICs one at a time instead of increasing the cluster size. Ensure the cluster is fully fit prior to decommission/recommission of each APIC. You can follow the below link for steps on replacing an APIC
APIC Hardware Replacement
This will not impact data plane traffic in the fabric
russhe
Hey Ziad,
