Cisco ACI GUI : Interface stats cannot be seen with a read-only account
I have a question related to the RBAC capabilities of ACI.
I have a TACACS user who has all/read-all role assigned with Cisco ACS(by using an AVP pair).
What I noticed is that it has read capabilities on most of the objects, except that he cannot see interface stats.
is there a way to provide someone's  account access to ACI and allow him to see all interface stats, but not to be able to change anything?
I tried with different roles, but I didn't figure it out how : read-all, ops, fabric-admin, access-admin.
The only role which have access to the interface stats is admin.
Andrei
dpita
Hello
Thanks for using SupportForums.
This is a very interesting questions. You are correct that the only privilege that has access to the stats tab would be admin read.
I looked in the API documentation included on all APICs and found the physical interface object l1PhysIf, then i saw it had some "stats" which related to the ones in the GUI/graph. i picked one at random which happened to be the "Ingress Unknown Bytes in 1 hour of sampling" or eqptIngrUnkBytesHist1h object which has a read access of admin.
Class eqpt:IngrUnkBytesHist1h (CONCRETE)
Class ID:3074
Class Label: historical Ingress Unknown Bytes stats in 1 hour
Encrypted: false - Exportable: false - Persistent: false - Configurable: false
Write Access: [NON CONFIGURABLE]
Read Access: [admin]
Creatable/Deletable: no (see Container Mos for details)
Semantic Scope: None
Semantic Scope Evaluation Rule: Parent
Monitoring Policy Source: Parent
Monitoring Flags : [ IsObservable: false, HasStats: false, HasFaults: false, HasHealth: false, HasEventRules: false ]
A class that represents historical statistics for Ingress Unknown Bytes in a 1 hour sampling interval. This class updates every 15 minutes.
you can find this information on your APIC under <APIC-IP>/doc/html/MO-eqptIngrUnkBytesHist1h.html
Ill ask the question internally regarding why statistics are only for admin. Seems like something Ops or some other team would like to have or need.
dpita
Hello
Class ID:3074
Thanks a lot.
If there is a way to provide access to another role, please let me know.
Andrei
Hi dpita,
I've similar question too..
My question is about cisco-av-pair value that needed to monitoring user.
We want user avalilable to see all configuration on apic but can't make configuration changes..
We've tried "read-all", but it can make configuration change. We've tried "ops" too, but we can't see full configuration on Tenant, fabric, etc..
So how "read-all" role can have "read-only" rules ? What is the value for cisco-av-pair needed on our Tacacs+ server
Hi Muhammad,
You may need to use the below AV-Pair, check the below link:
shell:domains = all//read-all (16003)
https://supportforums.cisco.com/t5/data-center-documents/configuring-tacacs-authentication-to-aci-fabric-with-cisco-acs/ta-p/3228328
