Cisco APIC: How to get model name for each controller, spine, and leaf via CLI
fc00::/7
What is the command to get model name for each controller, spine, and leaf via CLI?
show version don't have it.
    APIC03# show version
     Role        Pod         Node        Name             Version
     controller  1           1           APIC01     	3.2(4e)
     controller  2           2           APIC02     	3.2(4e)
     spine       1           1           SPINE01  	n9000-13.2(4e)
     spine       1           2           SPINE02  	n9000-13.2(4e)
     leaf        1           1           LEAF01  	n9000-13.2(4e)
     leaf        1           2           LEAF02  	n9000-13.2(4e)
show switch shows more info, but still no model name in it.
Sergiu.Daniluk
If you are interested only in model name, easiest way is to use moquery. I used grep to filter the name and model, but you can use plain output to see all related details to each node (role, rn, serial number, status etc)
apic1# moquery -c fabricNode | grep "model\|name "
model            : N9K-C9xxxx
model            : N9K-C9xxxx
model            : APIC-SERVER-xx
Sergiu
9 Replies 9
RedNectar
Hi @fc00::/7 ,
Try:
avread
fnvread
I know its 2 commands, but it should give you what you want
apic1# avread
Cluster:
fabricDomainName        ACI Fabric1
discoveryMode           PERMISSIVE
clusterSize             1
version                 apic-4.2(2f)
drrMode                 OFF
operSize                1
APICs:
                    APIC 1
version           4.2(2f)
address           10.1.0.1
oobAddress        172.16.11.111/24
routableAddress   0.0.0.0
tepAddress        10.1.0.0/16
podId             1
chassisId         xxx
cntrlSbst_serial  (APPROVED,xxx)
active            YES
flags             cra-
health            255
apic1# fnvread
        id               address  disabled    active  occupied permanent              model  nodeRole  nodeType  fabricId     podId
    101(1)      10.1.96.64/32(1)     NO(0)    YES(1)    YES(1)    YES(1) N9K-C93180YC-FX(1)      2(1)      0(1)      1(1)      1(1)
    102(1)      10.1.96.66/32(1)     NO(0)    YES(1)    YES(1)    YES(1) N9K-C93180YC-FX(1)      2(1)      0(1)      1(1)      1(1)
    201(1)      10.1.96.65/32(1)     NO(0)    YES(1)    YES(1)    YES(1)      N9K-C9332C(1)      3(1)      0(1)      1(1)      1(1)
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
for controllers try show controller command
I don't see model name in "show controller" command.
I'm looking for model name, e.g. Nexus 9000, not the hostname of that device.
Try these commands,
acidiag fnvread
acidiag avread
Thanks, but I can't run "acidiag" command
_exec_legacy_cmd:9: permission denied: /controller/sbin/acidiag
apic# avread
apic# fnvread
These commands are available starting with 4.2.X Not sure if present in 4.1.X as well.
apic# acidiag
apic# moquery
These ones are available in all versions.
Sergiu
Sergiu.Daniluk
model            : N9K-C9xxxx
model            : N9K-C9xxxx
Sergiu
The request to get the APIC model number is still answered. What I understand is: APIC is Cisco UCS server and the model number should be like UCS C220M or C240M-L3 etc.
RedNectar
Good point.  So actually get the model number is a 2 step process
Step 1 is to find the serial number of the APIC - this can be done using an moquery command
Step 2 is to paste the serial number into https://cway.cisco.com/sncheck/ (after logging in)
However, if you actually want to know the UCS model number, that will require Step 3 - which might be a bit tricky, but by searching for cisco apic CIMC software I found this table:
APIC Platform Corresponding UCS Platform Description
APIC-SERVER-M1 UCS-C220-M3 Cluster of three Cisco APIC first generation controllers with medium size CPU, hard drive, and memory configurations for up to 1000 edge ports.
APIC-SERVER-M2 UCS-C220-M4 Cluster of three Cisco APIC second generation controllers with medium size CPU, hard drive, and memory configurations for up to 1000 edge ports.
APIC-SERVER-M3 UCS C220 M5
APIC-SERVER-L1 UCS-C220-M3 Cluster of three Cisco APIC first generation controllers with large size CPU, hard drive, and memory configurations for more than 1000 edge ports.
APIC-SERVER-L2 UCS-C220-M4
Cluster of three Cisco APIC second generation controllers with large size CPU, hard drive, and memory configurations for more than 1000 edge ports.
APIC-SERVER-L3 UCS C220 M5
Cisco APIC with large CPU, hard drive, and memory configurations (more than 1200 edge ports)
Step 1
apic1# moquery -c infraWiNode | grep mbSn
mbSn           : FCH1907V0YZ
Step 2
