Cisco APIC M4 CIMC GUI Interfaces MLOM Not Shown
ZachM
We have a M4 server with CIMC configured and the below PCI cards installed however when I click on Networking, I only see Adapter Card 1, which based on the number of ports is the Cisco USC VIC 1455.  Is there anywhere in the CIMC GUI that I can see if the MLOM X710T dual port interfaces are up or do any type of configurations with those?
AshSe
Hey @ZachM
Let me share my understanding first:
  • You're trying to find the status and configuration options for the Intel X710-T based MLOM (Modular LAN on Motherboard) card in your Cisco APIC M4 server through the CIMC GUI, but you're only seeing the Cisco VIC 1455.
Below are some likely reasons due to which you are not able to see the X710-T in the CIMC GUI:
  1. Older version of CIMC
  2. Driver/firmware issue
  3. BIOS Setting: It's possible that the X710-T ports are disabled in the server's BIOS.
  4. Conflict in Resource Allocation
  5. Fault in MLOM card
AshSe
