Communication between 02 tenants in Cisco ACI
netbeginner
Level 2
Level 2
Hello All,
How to enable communication between 02 different Tenants in Cisco ACI.
What are the preventive measure to be taken while allowing communication between tenants.
Regds
Hi Robert,
Thanks !! But looks to be some gap.
I was requesting for APIC CLI commands for checking whether communication is allowed or denied between two different endpoints. If communication allowed then via which contract and if denies then what is the exact contract which is denying the communication.
Is this also what you are seeking with your other question?  If so, you better add this requirement to that question too.  In the meantime, everything I said in my reply to your other question also holds true here.
RedNectar aka Chris Welsh.
