EPG with only Static Port
BertiniB
I was testing a scenario with connecting a Legacy L2 Environment to ACI, in case a Nexus 5K connected via vPC to ACI. And when removing a the Domain configured for it I noticed that with only the Static Port configured, the VMs could still ping the Bridge Domain, only a fault was generated because of the absence of a Domain. However, if I did the same thing for a Baremetal with an Individual Port, it was no longer able to communicate with the Bridge Domain.
So I stumbled upon this post: https://community.cisco.com/t5/application-centric-infrastructure/epg-without-a-physical-domain-association/m-p/4920893#M14605
My Question is:
Is this behaviour possible because it is a Port-Channel or a vPC, since you specify the Policy Group which itself is linked to the VLAN Pool?
Because if I try this with an Individual Port which I only specify the interface, no Policy Group, it requires the Domain to work. However, the vPC works without a Domain.
Just trying to understand how ACI thinks.
RedNectar
HI @BertiniB ,
There are a couple of pieces missing in your jig-saw.
Your refer to a VPC connected to a Nexus 5K, and to VMs. Are we supposed to assume that the VMs are attached via the Nexus 5K????
And no matter which way the VMs are connected, is a Virtual Machine Management (VMM) Domain configured to manage ent VMs?
I think I'll wait till I get a clearer picture before replying. Remember, a picture is worth 1000 words.
RedNectar aka Chris Welsh.
BertiniB
Thanks for the reply @RedNectar!
Sorry for the lack of context. Here is my environment:
I am referring to that box called "Rede Legado Layer 2". And no, those VMs are not connected via VMM Domain. I was using a regular Physical Domain to connect such L2 Legacy environment represented by the N5K.
RedNectar
Hi @BertiniB ,
I tried to reproduce your scenario, but in my case once the Domain association was deleted, all pings to the Gateway IP stopped.
I made a
video for you
