Extend EPG's in two different tenants but with the same outside port
waleedmatter
I have two tenants (two different VRF's) and each one has different EPG's(different BD's and Vlan pool)  and the gateway will be the active firewall and physically the active and standby connected to the two borders as vpc
my question :
- i will extend the EPG's in the first tenants by adding the static path and select the policy group of the active firewall and add another one for the standby firewall for each EPG in this tenant
-i will do the same for the second tenant by by adding the static path and select the policy group of the active firewall and add another one for the standby firewall for each EPG in this tenant
Is this correct ?
tenant 1   tenant 2
port-channel firewall active/standy
Tarakesh Jetti
Could you please tell us what is the APIC version that you are using?
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco ACI through our live Ask the Experts (ATXs) session. Check out the ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
Thanks and regards,
Tarakesh Jetti
Customer Success Specialist - CX Team.
You can follow the below link for the supported Topologies.
https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/application-centric-infrastructure/white-paper-c11-739971.html#Topologyexamples
Thanks and regards,
Tarakesh Jetti
the latest version
