F0849 : Configuration failed due to invalid port
conf-t
How can I resolve this fault F0849 please? I didn't find the affected object on the GUI!
Thank you;
mfr-6
hi @conf-t
Have you checked if this is config is present under Fabric Policies under Fabric tab instead of Access Policies?
Mateusz Frak NetDevOps | DevNet | Automation DevNet Expert #20240068
Please mark this post as helpful if it solves your issue, to make this visible for other users, thank you!
Hi mfr-6,
Yes, I couldn't locate the affected object. I don't have any Policy Group with this name!
@conf-t If this is still the case, TAC can assist you with this. If this is a stale fault with no reflection in the policy model, then TAC can remove this fault for you.
