False alarm on ACI for port channel
RahmaSallm
We can see a Fault for a port-channel that does not exist in ACI.
topology/pod-1/node-105/sys/aggr-[po7]/aggrif
Port is down, reason being noOperMembers(connected), used by EPG,Infra on node 105 of fabric ACI Fabric1 with hostname *******
F0532
Critical
When checking for any interface connected to the port-channel on leaf105, we get nothing. Also, when crosschecking for po25 we can see that config exists
apic1# fabric 105 show inter | grep po7
apic1# fabric 105 show inter | grep po25
Belongs to po25
Is this a bug or a stale entry? If it's a stale entry how do we remove it?
Robert Burns
Provide the output of "show port-c summary" from that leaf
Robert
apic1# fabric 105 show port-c summ
Node 105 (leaf05)
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
        F - Configuration failed
Group Port-       Type     Protocol  Member Ports
      Channel
1     Po1(SU)     Eth      LACP      Eth1/31(P)
2     Po2(SU)     Eth      LACP      Eth1/48(P)
3     Po3(SU)     Eth      LACP      Eth1/47(P)
4     Po4(SU)     Eth      LACP      Eth1/35(P)
5     Po5(SU)     Eth      LACP      Eth1/22(P)
6     Po6(SU)     Eth      LACP      Eth1/17(P)
8     Po8(SU)     Eth      LACP      Eth1/11(P)
9     Po9(SU)     Eth      LACP      Eth1/8(P)
10    Po10(SU)    Eth      LACP      Eth1/19(P)
11    Po11(SU)    Eth      LACP      Eth1/15(P)
12    Po12(SU)    Eth      LACP      Eth1/21(P)
13    Po13(SU)    Eth      LACP      Eth1/20(P)
14    Po14(SU)    Eth      LACP      Eth1/29(P)
15    Po15(SU)    Eth      LACP      Eth1/23(P)
16    Po16(SU)    Eth      LACP      Eth1/34(P)
17    Po17(SU)    Eth      LACP      Eth1/24(P)
18    Po18(SU)    Eth      LACP      Eth1/27(P)   Eth1/28(P)
19    Po19(SU)    Eth      LACP      Eth1/5(P)
20    Po20(SU)    Eth      LACP      Eth1/33(P)
21    Po21(SU)    Eth      LACP      Eth1/38(P)
22    Po22(SU)    Eth      LACP      Eth1/9(P)
23    Po23(SU)    Eth      LACP      Eth1/36(P)
24    Po24(SU)    Eth      LACP      Eth1/30(P)
25    Po25(SU)    Eth      LACP      Eth1/32(P)
26    Po26(SU)    Eth      LACP      Eth1/25(P)   Eth1/26(P)
27    Po27(SU)    Eth      LACP      Eth1/13(P)
28    Po28(SU)    Eth      LACP      Eth1/12(P)
29    Po29(SU)    Eth      LACP      Eth1/7(P)
30    Po30(SU)    Eth      LACP      Eth1/10(P)
31    Po31(SU)    Eth      LACP      Eth1/18(P)
32    Po32(SU)    Eth      LACP      Eth1/6(P)
apic1#
Robert Burns
Looks like a a stale object.
Run this on your APIC CLI:
moquery -c pcAggrIf -f 'pc.AggrIf.id=="po7"'
Then run it on node 105:
Robert
