filter default route
mzouggagh
Frequent Visitor
Frequent Visitor
I have static default route configured in L3out-01
I have multiple OSPF L3outs with  0.0.0.0/0 and both “Export Route Control Subnet” and “Aggregate Export” are enabled
I need to filter default route when exporting route from one of the OSPF L3out.
what is the best option ? and how ?
Remi-Astruc
Hi @mzouggagh ,
Nice to meet you there.
To filter out 0.0.0.0/0 you need to use 2 subnets 0.0.0.0/1 + 128.0.0.0/1 instead of a single 0.0.0.0/0, then create and associate 2 route-maps, 1 matching 0.0.0.0/1 with Aggregate, 1 matching 128.0.0.0/1 with Aggregate. Resulting match will be mask between 1 and 32.
Remi Astruc
5 Replies 5
Remi-Astruc
Hi @mzouggagh ,
Remi Astruc
Hi @Remi-Astruc ,
Nice to meet you too.
so from l3out where I want to filter 0.0.0.0/0:
1) I delete 0.0.0.0/0 with “Export Route Control Subnet” and “Aggregate Export”  from L3out EPG
2) create default-export route map with  2 seq, 1 matching 0.0.0.0/1 with Aggregate, 1 matching 128.0.0.0/1 with Aggregate
correct ?
Remi-Astruc
Correct.
That assumes the other L3outs are set on different Border Leaves.
Remi Astruc
mzouggagh
Frequent Visitor
Frequent Visitor
Hi @Remi-Astruc
Thanks, your recommendation is working.
we tried an other method:
 1) 0.0.0.0/0 with “Export Route Control Subnet” and “Aggregate Export”  from L3out EPG
 2) created route control profile:
       - Match routing policy only
       - deny 0.0.0.0/0
       - permit all
Do you recommend this type of route map ?
Remi-Astruc
Hi @mzouggagh ,
Could be.
Keep in mind that specific subnets definition is still a best practice with Export Route Control to avoid issues.
Remi Astruc
