10-21-2016 01:23 AM - edited 03-01-2019 05:04 AM
Hello All,
It would be grateful, if could you please help me to know the following generic design queries of Cisco ACI:
1- how many Bridge Domains are allowed in EPG?
2- Can we have vlan 10 part of two VLAN pool pool-A and pool-B?
3- Can we add multiple encapsulation to the same physical port?
4- Can the same switch port below to two different EPG?
Thiyagu
10-21-2016 04:17 AM
Hi Thiyagu,
1) Only 1 BD can be associated with an EPG
2) Yes
3) Yes
4) Yes
An example is:
ANP - Outside
EPG - Outside_10 (VLAN 10 Encap) (Static Bind to Eth1) BD - Outside_10
EPG - Outside_11 (VLAN 11 Encap) (Static Bind to Eth1) BD - Outside_11
Ian
10-21-2016 05:46 AM
Keep in mind you can't have two different domains (physical, vmm, l3 or l2) all tied to the same interface using a single AEP. This will raise a fault due to overlapping VLANs.
Robert
