How do I disable SSL 2 and 3 on APICs
Heino Human
Hi guys,
I just upgraded our ACI infrastructure from 3.2 to 4.2. Now our security scan system within our network has alarmed stating
"The remote service accepts connections encrypted using SSL 2.0 and/or SSL 3.0"
How would I disable this in the APICs?
Thank you
Heino
Heino Human
Hi guys,
For anyone else who might run into this issue. With version 4.2 Cisco has opened port 8989 to the OOB mgmt network.
Once I created a filter to block traffic to the OOB mgmt network on port 8989, our security scans failed to see the open port.
7 Replies 7
Marcel Zehnder
Hi Heino
You'll find the SSL protocol config in the GUI at Fabric --> Fabric Policies --> Policies --> Pod --> Management Access --> default
Marcel
hi Marcel,
Yes, I have looked there, but there is no option to enable/disable SSLv2 or 3.
I have raised a TAC case for this and just waiting on our Cyber ops team to provide their details to TAC on how they found the APICs responding to these services.
Thank you
Heino
Indeed SSLv2/v3 must be disabled. Are you sure your scanner isn't reporting a false positive? Are you scanning port 443 or is this alarm for another port on the APIC?
Robert Burns
What scanning tool is your security team using?  Nessus?
Robert
Yes, that is one of them.
I should mention, this is only on port 8989 for SSLv2 and 3.
I have raised a case with Cisco TAC on this. I can't find any documentation related to it anywhere. Once I get an update, I will share it here.
I did run netstat command on the APICs and there are no communication on port 8989.
Heino Human
Hi guys,
hi!!!
Heino how do you block the traffic to OOB network on port 8989? with taboo contract or OOB contract?
Regards!!!
