Ingress Forwarding Drop Packets rate
agibulhasan
I'm getting the below fault error in SPINE switch. Node-202/sys/phys-[eth1/3] port is connected to LEAF switch pod-1/node-101/sys/phys-[eth1/49]. Please suggest me how can I solved this fault error.
Fault Code: F100696
Affected Obj:topology/pod-1/node-202/sys/phys-[eth1/3]
Description: TCA: Ingress Forwarding Drop Packets rate(eqptIngrDropPkts5min:forwardingRate) value 11 raised above threshold 10
0 Replies 0
