Interpret the output of a Cisco Nexus switch SNMP output.
Folks,
We got the below ooutput from a Cisco switch via SNMP polling.:
Cisco NX-OS(tm) aci, Software (aci-n9000-system), Version 21.0(4o), RELEASE SOFTWARE Copyright (c) 2002-2014 by Cisco Systems, Inc. Compiled 2015/**/** **:**:**
We need some help understanding what does "Version 21.0(4o)" mean because as per my knowledge there is no such version number.
Neel.
ashok_boin
Level 5
Level 5
Hi Neel,
This is in ACI mode and its version number.
https://supportforums.cisco.com/document/12268066/nexus-9000-standalone-nxos-aci-conversion-and-back
Ashok.
With best regards...
Ashok
Lets check basic things first.
1. Can you ping Cisco GSR's management's default gateway IP address.
2. Can you ping Cisco GSR's IP address with Arbor's loopback ip address.
I assume, you won't be able to ping in response to point number 2; as if you would have been, then there should not be any problem.
