05-22-2015 07:45 AM - edited 03-01-2019 04:50 AM
I need to route leak between VRFs in the same tenant, i know how to do it for Inter Tenant but i cannot get it working when inside the same tenant with two different VRFs using different BD.
any ideas
thanks
Solved! Go to Solution.
05-22-2015 08:40 AM
Hey Chris,
Route leaking between VRFs in the same tenant turns out to be very similar to route leaking between VRFs in different tenants.
Here's an example for route leaking between 2 VRFs in the same tenant:
Example Topology:
EPG-1 in BD-1 in VRF-1
EPG-2 in BD-2 in VRF-2
Contract-1 is defined as a global contract.
- Pick one EPG to be the Provider and the other EPG to be the Consumer, for this example EPG-1 will be the provider and EPG-2 will be the consumer.
- Define the provider subnet as shared under EPG-1. (Provider side = subnet defined under EPG)
- Define the consumer subnet as shared under BD-2. (Consumer side = subnet defined under BD)
- Export Contract-1 to the SAME tenant.
- EPG-1 will provide Contract-1
- EPG-2 will consumer Contract-1 as a contract interface.
You can verify the routes are leaked between VRFs on the CLI of the necessary leafs, with the following command:
leaf# show ip route vrf <Tenant:Context>
Hope this helps.
05-22-2015 08:40 AM
Hey Chris,
Example Topology:
Hope this helps.
05-22-2015 09:46 AM
awesome, thats what i did do, perhaps my config is wrong. let me try it again.
cheers
