06-27-2023 01:55 AM - edited 06-27-2023 02:01 AM
I am trying to increase the MTU of my L3out routed ports to 9216,
when I increased the MTU on one of the ports and pinged it form the other side with a 9216 byte icmp packet, it received the request and responded with a 1500 byte icmp reply. And once I try to initiate a ping larger then 1500 byes from the interface it doen't send anything.
When running "show interface {interface}" the MTU is set to 9216.
Does anyone have any idea why this is happening?
06-28-2023 03:29 AM
is the device (router) you try to reach via ping from ACI is directly connected or is there a switch in between?
...and -
06-28-2023 08:05 AM
The problem isn’t with the device i am trying to reach. The routed port on the border leaf will not even sent the packets if they are larger then 1500 and the df flag is set
07-04-2023 12:23 PM - edited 07-14-2023 06:15 AM
I guess, you're using the "iping"-command beeing connected using SSH to a ACI-Leaf switch.
The packet-size-parameter of "iping" specifies the "data-portion" of the ICMP-Message sent.
So, if IP-MTU=9000 should be possible specify 8972 bytes.
get added.
The result is an IP-Packet with size 8972+20+8=9000 Byte.
In my example, an IP-MTU of 9000 is possible, so
leaf1# iping -V MTUTEST:DEFAULT 172.16.0.202 -F -s 8972
PING 172.16.0.202 (172.16.0.202) from 172.16.0.201: 8972 data bytes
8980 bytes from 172.16.0.202: icmp_seq=0 ttl=254 time=1.003 ms
8980 bytes from 172.16.0.202: icmp_seq=1 ttl=254 time=6.615 ms
8980 bytes from 172.16.0.202: icmp_seq=2 ttl=254 time=0.864 ms
8980 bytes from 172.16.0.202: icmp_seq=3 ttl=254 time=0.893 ms
^C
--- 172.16.0.202 ping statistics ---
4 packets transmitted, 4 packets received, 0.00% packet loss
round-trip min/avg/max = 0.864/2.343/6.615 ms
leaf1# iping -V MTUTEST:DEFAULT 172.16.0.202 -F -s 8973
PING 172.16.0.202 (172.16.0.202) from 172.16.0.201: 8973 data bytes
Request 0 timed out
Request 1 timed out
Request 2 timed out
^C
4 packets transmitted, 0 packets received, 100.00% packet loss
just to prove, that the packet gets lost by MTU too big - I'll repeat the command without the "don't fragment"-option:
leaf1# iping -V MTUTEST:DEFAULT 172.16.0.202 -s 8973
8981 bytes from 172.16.0.202: icmp_seq=0 ttl=254 time=1.084 ms
8981 bytes from 172.16.0.202: icmp_seq=1 ttl=254 time=0.893 ms
8981 bytes from 172.16.0.202: icmp_seq=2 ttl=254 time=1.014 ms
8981 bytes from 172.16.0.202: icmp_seq=3 ttl=254 time=1.093 ms
8981 bytes from 172.16.0.202: icmp_seq=4 ttl=254 time=1.034 ms
^C
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.893/1.023/1.093 ms
07-04-2023 12:29 PM - edited 07-14-2023 06:15 AM
if this doesn't help we might need to check your L3Out-setup if your neighbor-device is fine.
...some ideas
leaf1# show interface ethernet 1/48
Ethernet1/48 is up
admin state is up, Dedicated Interface
Hardware: 1000/10000 Ethernet, address: 0000.0000.0000 (bia 7c0e.cecb.cc0a)
MTU 9216 bytes, BW 1000000 Kbit, DLY 1 usec
For L3-IP traffic there might be a (lower) limit at the IP-Interface.
leaf1# show ip int brief vrf MTUTEST:DEFAULT
IP Interface Status for VRF "MTUTEST:DEFAULT"(8)
Interface Address Interface Status
eth1/48.29 172.16.0.201/30 protocol-up/link-up/admin-up
vlan19 172.16.100.254/24 protocol-up/link-up/admin-up
lo2 172.16.255.201/32 protocol-up/link-up/admin-up
leaf1# show int e1/48.29
Ethernet1/48.29 is up
admin state is up, Dedicated Interface, [parent interface is Ethernet1/48
Internet Address is 172.16.0.201/30
MTU 9000 bytes, BW 1000000 Kbit, DLY 1 usec
Encapsulation ARPA, medium is broadcast
11-24-2023 10:46 AM
Not sure if you already know the reason.
Anyway, looks like the iping mtu is configured by the control plane MTU which is configured under the system setting. It took me awhile to figure it out.
