L3 peering over VPC between ACI Leafs and VSS MEC
Hi, I need to configure L3out using OSPF between ACI Border Leafs and VSS (virtual switch system). Idea is to connect them with a 4 x ports back-to-back VPC (or MEC in the VSS terminology) and then use sub-interfaces on the PO level. (Diagram attached).
Just checking if this is a supported design?
Shyam Sundar
This seems to be a valid configuration from the ACI perspective (a device connected with vPC to a L3Out and running a routing protocol with ACI) and if VSS MEC matches the L2\3 configurations similar to ACI, this must be feasible.
P.S. I am not aware if Cisco engineering has tested this configuration and support the same.
Shyam Sundar
