04-15-2019 11:06 PM
Hi community,
I created various l3outs in my fabric including one in the infra tenant for mPod.
I want to automate everything to get rid of the CLI and GUI.
Everything works so far including the multipod, but I have the following errors in my fault log for each l3out interface id. The source is the external EPG (l3extinstP) under the l3outs:
Fault code: F0467
configuration-failed - Fault delegate: Configuration failed for uni/tn-infra/out-multipod/instP-EPG-L3OUT-MPOD-CORE node 101 eth1/65 due to Invalid Path Configuration, debug message: invalid-path: Either the EpG is not associated with a domain or the domain does not have this interface assigned to it;
So first things first:
The routed interfaces are configured under the l3out in the external interface profiles (l3extLIfP). So, from my understanding, there must not be any fabric/access interface policy group for these kind of interfaces, right? The l3outs are assigned to the correct external domais.
04-16-2019 01:35 AM
Just to follow up. For the mPod L3out I'm obiously hitting CSCvh06474 / CSCvb46222
This doesn't explain the errors for the other (non-mPod) l3outs
04-16-2019 06:35 AM - edited 04-16-2019 06:37 AM
For the non mPOD L3 outs you need all the access policies. The interface policy group will tie to an AAEP which will map to your L3 domain.
04-16-2019 10:36 PM
Hey micgarc2,
thanks for the explaination. I did this and got another error. My L3Out physical ports are trunks, consisting of routed sub-interfaces (muliple l3outs of different VRFs are using the same physical port...each VRF L3out has dedicated transit VLANs / typical firewall-on-a-stick design).
Fault delegate: Configuration failed for node <NODE-ID> due to Interface Configured as L3, debug message: port-configured-as-l3: Port has one or more layer3 sub-interfaces;
My Access Policy (infraAccPortGrp) just consists of a CDP and LLDP policy (both enabled) and the AEP, holding the l3 domain with the correct VLAN pool (containing the l3out transit VLAN IDs).
10-08-2019 06:19 AM
I solved it, desconfiguring and configuring the Switch Profile of the Spine.
