L3Out node/interface profiles
AirBorn
I have 2 firepower configured in active/standby mode to connect to 2 ACI Leaf switches ( see attached file) through two VPC links VPC-Pathe-1 & VPC-Path-2
the setup is for internal Network <--> DC communications only
OSPF is used
I have configured a L3out   with one node profile wich contails 2 interface profile
- interface profile 1 :
   - Path: VPC-Path-1
   - VLAN=2010
   - Side A Primary IP: 10.1.1.1/24
   - Side B Primary IP: 10.1.1.2/24
- interface profile 2 :
   - Path: VPC-Path-2
   - VLAN=2010
When i configure interface profile 2 with he above parameters i get "ip address mismatch" error 400. i have also tested
    - Interface profile 2 with different IP on the same subnet
    - Adding VPC-Parh-2 to  interface profile 1
i still get the error message
Cisco documentation says " configuring the same VLAN on two different Paths as an SVI is supported"
Does the above design not supported ? if yes what is the alternative design ?
It seems like there was a bug on the dcloud, the setup is working fine now.
Francesco Molino
 can you share the screenshot of apic when you’re configuring these IPs on the same interface profile for both paths?
 This works and all setups with HA firewalls, this is the way to do it: SVI with same IPs on both paths.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
