Moquery to check unused EPGs
Jarurug
Hi All,
We have 300+ EPGs in our Environment and some of them are not used.
Is there a Moquery to list all the unused EPGs?
9 Replies 9
RedNectar
Hi @Jarurug ,
Maybe I should write a blogpost about how to ask a good question!
In the meantime, I'm struggling to understand what you mean by "unused EPGs"
It could mean EPGs that have no:
  • endpoints
  • static path mappings
  • provided or consumed contracts
  • physical or VMM domain associated with it
  • perhaps something else I haven't thought of
Anyway, I'm going to ASSUME you mean EPGs that have no provided or consumed contracts.
And I'm going to use icurl rather than moquery - I may translate the icurl answers to moquery later if I get time (BTW, moquery just translates your queries to icurl anyway - and not always accurately)
Because icurl uses ? and & characters in the command, you can assume all the following examples have been entered from a bash command shell, not the APIC CLI
The following will give you a list of the dn (distinguished or unique name) of every EPG in the system.
apic#1 bash
T17@apic1:~> icurl -s http://localhost/api/node/class/fvAEPg.json | jq -r '.imdata[].fvAEPg.attributes.dn' | sort
The following will give you a list of the dn (distinguished or unique name) of every EPG in the system that either provides or consumes a contract. [Scroll right - it's a LONG command]
apic#1 bash
T17@apic1:~> icurl -s http://localhost/api/node/class/fvAEPg.json?'query-target=subtree&target-subtree-class=fvAEPg&rsp-subtree=children&rsp-subtree-class=fvRsCons&rsp-subtree-include=required&rsp-subtree-class=fvRsProv&rsp-subtree-include=required' | jq -r '.imdata[].fvAEPg.attributes.dn' | sort | uniq
If you pipe each output into a text file, you can use comm to find all EPGs that have NO provided or consumed contracts.  Below I piped all EPGs into a file called all, and the contracted EPGs into a file called contracted.  You can see that on my lab, there are six EPGs that have neither consumed or provided contracts.
apic#1 bash
T17@apic1:~> icurl -s http://localhost/api/node/class/fvAEPg.json | jq -r '.imdata[].fvAEPg.attributes.dn' | sort > all T17@apic1:~> icurl -s http://localhost/api/node/class/fvAEPg.json?'query-target=subtree&target-subtree-class=fvAEPg&rsp-subtree=children&rsp-subtree-class=fvRsCons&rsp-subtree-include=required&rsp-subtree-class=fvRsProv&rsp-subtree-include=required' | jq -r '.imdata[].fvAEPg.attributes.dn' | sort | uniq > contracted
T17@apic1:~> comm -3 all contracted # the -3 option suppresses lines that appear in both files
uni/tn-infra/ap-access/epg-default
uni/tn-infra/ap-ave-ctrl/epg-ave-ctrl
uni/tn-Tenant01/ap-2Tier_AP/epg-AppServers_EPG
uni/tn-Tenant01/ap-2Tier_AP/epg-DBServers_EPG
uni/tn-Tenant03/ap-2tier_ap/epg-WebServers_EPG
uni/tn-Tenant05/ap-2Tier_AP/epg-DBServers_EPG
uni/tn-Tenant18/ap-3Tier_AP/epg-DBServers_EPG
BTW - if you want a cool print of all EPGs and the contracts that the provide and consume, try this.
T17@apic1:~> icurl -s http://localhost/api/node/class/fvAEPg.json?'rsp-prop-include=naming-only&query-target=subtree&target-subtree-class=fvAEPg&rsp-subtree=children&rsp-subtree-class=fvRsCons&rsp-subtree-include=required&rsp-subtree-class=fvRsProv&rsp-subtree-include=required' | jq
RedNectar aka Chris Welsh.
RedNectar
Hi @Jarurug ,
I'm guessing you were not satified with my last answer because I gave you an icurl answer when you asked for a moquery answer.
I did say in my first answer that "I may translate the icurl answers to moquery later if I get time"
Well, I got time and can now tell you that the many bugs in moquery make it impossible to solve this problem using moquery in exactly the same way.
But I found a work-around
apic#1 moquery -c fvAEPg -o json | jq -r '.imdata[].fvAEPg.attributes.dn' | sort
The following SHOULD give you a list of the dn (distinguished or unique name) of every EPG in the system that either provides or consumes a contract.
apic#1  moquery -c fvAEPg -o json -x "query-target=subtree target-subtree-class=fvAEPg rsp-subtree=children rsp-subtree-class=fvRsCons rsp-subtree-include=required rsp-subtree-class=fvRsProv rsp-subtree-include=required"| jq -r '.imdata[].fvAEPg.attributes.dn' | sort
Unfortunately, it lists ONLY EPGs that provide a contract.  So it may as well be simplified to:
apic#1  moquery -c fvAEPg -o json -x "query-target=subtree target-subtree-class=fvAEPg rsp-subtree=children rsp-subtree-class=fvRsProv rsp-subtree-include=required"| jq -r '.imdata[].fvAEPg.attributes.dn' | sort
And you can get all the EPGs that consume a contract using
apic#1  moquery -c fvAEPg -o json -x "query-target=subtree target-subtree-class=fvAEPg rsp-subtree=children rsp-subtree-class=fvRsCons rsp-subtree-include=required"| jq -r '.imdata[].fvAEPg.attributes.dn' | sort
As before, if you redirect each output into a text file, combining the provided and consumed contracts list using temp file, you can use comm to find all EPGs that have NO provided or consumed contracts.  Below I piped all EPGs into a file called all, and sorted the the contracted EPGs into a file called contracted
Note the >> double redirection on the 3rd moquery command so the output gets appended to the temp file,
apic#1 bash
T17@apic1:~> moquery -c fvAEPg -o json | jq -r '.imdata[].fvAEPg.attributes.dn' | sort > all T17@apic1:~> moquery -c fvAEPg -o json -x "query-target=subtree target-subtree-class=fvAEPg rsp-subtree=children rsp-subtree-class=fvRsProv rsp-subtree-include=required"| jq -r '.imdata[].fvAEPg.attributes.dn' | sort > temp
T17@apic1:~> moquery -c fvAEPg -o json -x "query-target=subtree target-subtree-class=fvAEPg rsp-subtree=children rsp-subtree-class=fvRsCons rsp-subtree-include=required"| jq -r '.imdata[].fvAEPg.attributes.dn' | sort >> temp
T17@apic1:~> sort temp | uniq > contracted
Hopefully this answer will satisfy you!
Marcel Zehnder
Hi to get a list of EPGs with no endpoints in it, you can do the following (on a APIC):
moquery -c fvAEPg | grep dn | grep epg | awk '{print $3}' | sort > /tmp/all_epgs
moquery -c fvCEp | grep dn | grep epg | awk '{print $3}' | cut -d "/" -f1-4 | sort | uniq > /tmp/epgs_with_endpoints
grep -vf /tmp/epgs_with_endpoints /tmp/all_epgs
If only we knew what was mean by "unused EPGs"
  • endpoints = see Marcel's answer
  • provided or consumed contracts = see my previous answers
Let's hope @Jarurug responds with some more information
Thanks for helping @RedNectar.
Sorry if my question was not proper. Am trying to find a Moquery to list EPGs which doesn't have any EndPoints associated with it.
Hi @Jarurug ,
You say:
Then I'm pretty sure @Marcel Zehnder 's answer has nailed it. And it will help others find the correct answer if you mark it correct.
However, just for fun, I'll give you the same answer using icurl and jq - just because I figured it out and others may find it helpful.  And I got a bit carried away, adding a few other options.
Find EPGs with no endpoints
The following will give you a list of the dn (distinguished or unique name) of every EPG in the system and put the list in a file called /tmp/all_epgs
apic#1 bash
jq -r '.imdata[].fvAEPg.attributes.dn' | sort > /tmp/all_epgs
The following icurl command will give you a list of every endpoint in the system in an EPG, including its dn. That dn will begin with the dn of the EPG to which it belongs - something like
uni/tn-Tenant10/ap-2Tier_AP/epg-WebServers_EPG/cep-B4:96:91:89:16:5F
so we use jq to separate out the dns of the EPG and send them to a different file /tmp/epgs_with_endpoints
T17@apic1:~> icurl -s http://localhost/api/node/class/fvCEp.json?'query-target-filter=wcard(fvCEp.dn,"epg-")' |
jq -r '.imdata[].fvCEp.attributes | (.dn|capture("(?<E>.*)/cep-").E)' | sort | uniq > /tmp/epgs_with_endpoints
And finally, you can use either comm or grep to get the difference between the files.
T17@apic1:~> comm -3 /tmp/all_epgs /tmp/epgs_with_endpoints     ;# or
T17@apic1:~> grep -vf /tmp/epgs_with_endpoints /tmp/all_epgs
Don't forget to clean up!
T17@apic1:~> rm /tmp/all_epgs ;rm /tmp/epgs_with_endpoints
Find EPGs with no static mappings
apic#1 bash
The following icurl command will give you a list of static mapping for all EPGs, including its dn. That dn will begin with the dn of the EPG to which it belongs - something like
uni/tn-Tenant10/ap-2Tier_AP/epg-WebServers_EPG/rspathAtt-[topology/pod-1/paths-2201/pathep-[eth1/27]]
so we use jq to separate out the dns of the EPG and send them to a different file /tmp/epgs_with_static_maps
T17@apic1:~> icurl -s http://localhost/api/node/class/fvRsPathAtt.json?\
'query-target-filter=wcard(fvRsPathAtt.dn,"epg-")' |
jq -r '.imdata[].fvRsPathAtt.attributes | (.dn|capture("(?<E>.*)/rspathAtt-").E)' |
sort | uniq > /tmp/epgs_with_static_maps
T17@apic1:~> comm -3 /tmp/all_epgs /tmp/epgs_with_static_maps     ;# or
T17@apic1:~> grep -vf /tmp/epgs_with_static_maps /tmp/all_epgs
T17@apic1:~> rm /tmp/all_epgs ;rm /tmp/epgs_with_static_maps
Find EPGs with no provided or consumed contracts
apic#1 bash
The following icurl command will give you a list of the dn (distinguished or unique name) of every EPG in the system that either provides or consumes a contract.  We use jq to separate out the dns of the EPGs with contracts and send them to a different file /tmp/epgs_with_contracts
T17@apic1:~> icurl -s http://localhost/api/node/class/fvAEPg.json?\
'query-target=subtree&\
target-subtree-class=fvAEPg&\
rsp-subtree=children&\
rsp-subtree-class=fvRsCons,fvRsProv&
jq -r '.imdata[].fvAEPg.attributes.dn' | sort | uniq > /tmp/epgs_with_contracts
T17@apic1:~> comm -3 /tmp/all_epgs /tmp/epgs_with_contracts     ;# or
T17@apic1:~> grep -vf /tmp/epgs_with_contracts /tmp/all_epgs
T17@apic1:~> rm /tmp/all_epgs ;rm /tmp/epgs_with_contracts
Find EPGs with no Physical Domain or VMM Domain
apic#1 bash
The following icurl command will give you a list of domain associations for all EPGs, including its dn. That dn will begin with the dn of the EPG to which it belongs - something like
uni/tn-Tenant10/ap-2Tier_AP/epg-WebServers_EPG/rsdomAtt-[uni/phys-T17:MappedVLANs_PhysDom
so we use jq to separate out the dns of the EPG and send them to a different file /tmp/epgs_with_domain
T17@apic1:~> icurl -s http://localhost/api/node/class/fvRsDomAtt.json?\
'query-target-filter=wcard(fvRsDomAtt.dn,"epg-")' |
jq -r '.imdata[].fvRsDomAtt.attributes | (.dn|capture("(?<E>.*)/rsdomAtt-").E)' |
sort | uniq > /tmp/epgs_with_domain
T17@apic1:~> comm -3 /tmp/all_epgs /tmp/epgs_with_domain  ;# or
T17@apic1:~> grep -vf /tmp/epgs_with_domain /tmp/all_epgs
T17@apic1:~> rm /tmp/all_epgs ;rm /tmp/epgs_with_domain
Thanks Marcel.
I was looking for this Only(EPG with no EndPoints)
However, this EPGs which am getting from your Moquery still have Endpoints associated with it. Have checked the same with TAC but they also don't seem to have an solution for this.
Remi-Astruc
Hi @Jarurug ,
Then, in the @Marcel Zehnder 's script, just replace fvCEp with fvRsPathAtt
If that's what you needed, all the credit goes to him...
Hi Marcel, long time I've not been around, nice to see you again!
Remi Astruc
Hi @Remi-Astruc Same here, I did not have to much time for the community recently. Nice to see you!
