Bookmark
Subscribe
2832
Moquery - what does "rsp" stand for in "rsp-subtree" ?
vv0bbLeS
Hello all,
I'm honestly curious if anyone knows what "rsp" stands for in the advanced filter option rsp-subtree of moquery in ACI ?
My guess would be that it may be shorthand for "response", or perhaps it stands for "Request Scope Property" ?
0xD2A6762E
Sergiu.Daniluk
Based on the description from ACI REST API documentation, I would say is simply short for "response".
rsp-subtree={no | children | full}
For objects returned, this option specifies whether child objects are included in the response. This list describes the available choices:
  • no —(Default) Response includes no children.
  • children —Response includes only the children.
  • full —Response includes the entire structure including the children
Ref: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/2-x/rest_cfg/2_1_x/b_Cisco_APIC_REST_API_Configuration_Guide/b_Cisco_APIC_REST_API_Configuration_Guide_chapter_01.html
Good question though.
Sergiu
5 Replies 5
Sergiu.Daniluk
Sergiu
@Sergiu.Daniluk
Thanks! I had actually also looked at that link and those descriptions is what led me to think it may stand for "Response." I like learning what those things stand for as it helps me remember the syntax a bit better. Thanks for the confirmation!
0xD2A6762E
I was going to suggest:
Reply Sergiu Please
- but you beat me to it!
RedNectar aka Chris Welsh.
Hahahahha
d.cantele1
RSP = Route Switch Processor
