MP-BGP , IS-IS, COOP
mgual57
Can someone explain to me what are doing those 3 technologies ?
19 Replies 19
Hi Chris,
This is your perfect & evergreen explanation which help a lot of people to understand the flow.
I want to add here some thing by taking your line " But the leaf is a bit more clever than that, and looks INSIDE the payload of the ARP packet and learns that Host1 also has an IP address of 192.168.1.1 and records all this information in its Local Station Table "
Its become clever (in terms of IP learning) only when we enable Unicast Routing under L3 Configuration on BD.
Please make me correct if I am wrong because lots a of people reading this thread.
Thanks Chris.
Hi @TangoAlfa ,
You are absolutely correct.  If an ACI BD is configured in L2 Only mode (i.e.  Unicast Routing is disabled for the BD) then all fancy features (including inspection of ARP packets) dissolve. I always feel that using ACI as a L2 replacement is like doing parcel deliveries in a Ferrari - gets the job done very comfortably but a bit of overkill.
RedNectar aka Chris Welsh.
Nice Example
mgual57
Ok i got this , thanks you so much. Very clear explaination
moj_ccie
That was Great
As you (RedNectar) Say:
IS-IS Robust Routing Protocol is IP Fabric in ACI Underlay (It's mean for Establish Great IP Routing For All Leaf & Spine in Fabric) == Transparent & Permanent
BGP Exterior Routing Protocol is Only For L3Out, WAN Network (ISN) & Multi-Site & Multi-POD IP Routing Establishment - From Leaf should be Redistributed Route Table (Ingress BGP - Egress OSPF/EIGRP)
COOP Oracle Protocol For:
1: Update Local Station Table (Leaf Host Table) to Proxy Station Table (Spine Table)
2: Update Proxy Station Table (Spine Table) of All Spine in Fabric
3. Proxy Spine Anycast
 Best Regards.
