10-18-2017 01:25 PM - edited 03-01-2019 05:21 AM
Help Me
I have a LAB with 4 IPNs. With 2 IPNs per pod. And 2 Spines per pod however the spines are only connected to 1 IPN (see image)
Should there only be 1 IPN TEP address in each pod that's shared by spine 1 and 2 ?
Or should there be a IPN TEP address for each spine.
I am asking this because policy is not being pushed properly to pod 2 (APIC is in POD 1, only one APIC available for now)
10-18-2017 03:40 PM
10-18-2017 03:59 PM
10-19-2017 03:40 AM
10-19-2017 06:26 AM
Thanks guys for the info,
@nvermand I the TEP I am referring to is the one used for BGP. I am presuming CP-ETP stands for Control Plane Evpn Tunnel end point.
I can now ping the CP-ETEP at both ends. FYI I fixed this by simply removing and re-adding the setting at the following location.
Fabric-> Inventory -> Topology -> click "CONFIG" in the interpod interactive map -> POD Connection Profile.
In this section you have to specify a POD ID and a Dataplane TEP (CP-ETEP) for each POD. I removed and re-added and I can now ping the CP-ETEP from the IPN's. However in this section I have only 2 entries. From what I have understood in your reply I should have 4 entries in here as i have 4 spines??
Current settings:
POD ID Dataplane TEP
1 10.10.10.1/32
2 10.10.10.2/32
What my settings presumably should look like.??
1 10.10.10.1/32
2 10.10.10.2/32
1 10.10.10.3/32
2 10.10.10.4/32
11-18-2020 06:54 AM
~The post seems old, but how did you manage to solve the issue?
