NEXUS
TSR
I am facing some issues while converting the 9000 NXOS to ACI mode and need some inputs on this.
Version information:
Software
BIOS: version 05.39
NXOS: version 9.3(2)
BIOS compile time: 08/30/2019
NXOS image file is: bootflash:///nxos.9.3.2.bin
NXOS compile time: 11/4/2019 12:00:00 [11/04/2019 22:13:33]
Hardware
cisco Nexus9000 C93360YC-FX2 Chassis
Intel(R) Xeon(R) CPU D-1526 @ 1.80GHz with 24570348 kB of memory.
Processor Board ID FDO24030144
Device name: OCI_Test_SW1
bootflash: 115805708 kB
Kernel uptime is 0 day(s), 0 hour(s), 10 minute(s), 26 second(s)
Last reset at 100480 usecs after Thu Jul 25 19:14:11 2024
Reason: Reset Requested by CLI command reload
System version: 9.3(2)
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
TEST(config)# no boot nxos
TEST(config)# boot aci bootflash:aci-n9000-dk9.16.0.5h-cs_64.bin
Warning: Please check list of all ACI supported hardware before doing this operation, not all hardware are supported.
Warning: Booting to an ACI image will remove all nxos configuration and format bootflash. Do you want to continue (y/n)?[n] y
Performing image verification and compatibility check, please wait....
Unable remove internal file
Error opening the image /bootflash//aci-n9000-dk9.16.0.5h-cs_64.bin. err = 0x80a3004b
Failed to get image software id. Aborting..
TES(config)#
2 Accepted Solutions
AshSe
Hi @TSR
Below are the steps of
Converting N9K from Cisco NX-OS to ACI Boot Mode, Using a USB drive.
Equipment Required:
  1. Laptop with USB port access.
  2. Pen drive (FAT-32)
  3. Console Cable
Procedure:
  1. Format a USB pen drive with FAT32 file system
  2. Copy the ACI image in the USB pen drive.
  3. Login to the switch and check the ACI image using below command
Switch# dir usb1:
(or dir usb2: depending on which USB slot you have plugged the drive into)
4. Copy the ACI image to the bootflash
Switch# copy usb1:<ACI-image-name> bootflash:
Note: In case of modular chassis e.g. N9508 etc.; If you have a dual-supervisor system, you have an additional step, which is to copy the ACI image to the standby supervisor module:
Switch(config)# copy bootflash:aci-image bootflast://sup-standby/
5. Upgrade the image using below steps:
  •          Turn off NX-OS mode.
  •          Make sure that the first change survives a reboot.
  •          Boot the supervisor modules using the ACI image specified.
  •          Perform a switch reload
Switch(config)# no boot nxos
Switch(config)# copy running-config startup-config
Switch(config)# boot aci bootflash:aci-image-name
Switch(config)# reload
Once the switch is rebooted with the new image, you can log in.
It should work. I upgraded less than a year back sans issue. Please recheck.
Did you format your pen drive using FAT32 file system?
5 Replies 5
AshSe
Hi @TSR
Equipment Required:
  3. Console Cable
Procedure:
Switch# dir usb1:
I followed the same steps but no luck. Back in 2018 I did the same process it was working at that time but not now.
D Hart
I had this issue and had to load the ACI by breaking the startup and loading the ACI boot there.
dir usb1:
(locate ACI image and copy, if it states usb not found please use steps to format usb on the switch below)
conf t
no boot nxos
exit
copy usb1:/(ACI bin file) bootflash:
(wait for copy to finish)
copy run start
reload
(use control C to break the startup process once you see start up texts on the screen)
loader > boot bootflash:(ACI bin file)
(Should see a banner statement saying Converting switch from NXOS to ACI mode, reboot will take 15 minutes or so)
