On ACI how do we check and confirm DHCP is not managed by Switch ?
Hi Team ,
How do we check for a given subnet DHCP is on the switch or on the server or on the 3rd party IPAM ?
Thank you .
6 Replies 6
Robert Burns
DHCP (other than the Infra subnet) isn't managed by ACI.  ACI simply relays DHCP offers if configured to do so.   If you're asking if a subnet is currently defined on ACI as a Bridge Domain (BD) that's another question.  Please clarify.
Robert
Yes , BD configured on ACI for these BD subnets ..Will there be ny configuration related to DHCP in ACI ?
The only 'DHCP" specific config that relates to ACI would be if you needed to implement DHCP relay for your hosts to relay their DHCP requests to a dhcp server/IPAM in a different subnet/EPG.  There's plenty of guides online detailing how to setup dhcp relay on ACI.  If your dhcp server/IPAM is connected to the same EPG as the clients, there's no additional configure required as they'll have L2 connectivity between client & server.
If you want to see which BD subnets are configured across the entire fabric, the quickest method is to poll the API or use CLI.  From any APIC you can use:
moquery -c fvSubnet | egrep "ip|dn"
This will show you all the Subnets configured on Bridge Domains.
Robert
Will this command work on the leaf switch ?
No, its a fabric wide command.  If you want something specific to the leaf, just use "show ip int brief".
Robert
ashishr
Hi @Network_Sarovani
To check DHCP relay on leaf switch you can use the following CLI-
show dhcp internal info relay address interface [leaf:interfaceVlan#]
You can find more CLI here-
https://community.cisco.com/legacyfs/online/attachments/document/technote-aci-dhcprelay_external-v7.pdf
AR
