07-19-2022 09:27 AM
Hi, I am in the midst of designing a Remote Leaf (RL) solution and am wondering about their oob-mgmt ips. Since all the switches get assigned their oob-mgmt ips from the APIC where a pool/range is configured for the mgmt default oob epg, but in the case of the RLs since they are present in a different location/DC, that management network is not available there.
Can we have a separate pool/range just for the RLs?
thanks and appreciate your guidance!
Solved! Go to Solution.
07-19-2022 12:11 PM
Yes. The management IP of any node can be in as many subnets as you wish. No issues having RLs using subnet-B, while the rest of the primary fabric is using subnet-A.
If you had a large # of RLs, you could still use separate Mgmt IP Pools just to make the allocation quicker. Static is just easier this type of one-time activities.
Robert
07-19-2022 11:00 AM
Just statically assign your RL Management IPs. Then no pools are required.
Robert
07-19-2022 11:12 AM
Thanks Robert, you mean assign them static ips (a management network different from the primary site) from the APIC?
07-19-2022 12:11 PM
Robert
