06-30-2024 02:46 AM
We have deployed following set up on ACI
Example:
Tenant A -----> VRF A------> BD 1-----> EPG A, EPG B, EPG C(Production)
Tenant A -----> VRF A------> BD 2-----> EPG D
Now , We have a new requirement to use Same IP of EPG A which is not communicate to anyone under Non Production
Same IP will be use on both Production and Non Production(should communicate only to Specific resource)
What is the Best Practice configuration to achieve above requirement on ACI.
if it is possible, Please share a configuration guide.
Thanks in Advance
Regards ,
Mohammed Asif
07-12-2024 03:09 AM
Hello Asif,
My answers below:
Q. Can i use existing(Prod_Vrf) below L3 Out for Non-Prod_Vrf?
A. No
Diagram showing non-ACI VRF Deployment:
07-12-2024 03:50 AM
Hello Ashse,
For Non-Prod Vrf, Can i use existing AAEP and Physical Domain or Do i need to configure New?
Thanks in Advance
Mohammed Asif
07-12-2024 03:20 PM
Hello Asif,
You have to do new Access Policy configuration including new "External L3 Domain"
AshSe
07-11-2024 11:08 PM
Yes, I second @RedNectar opinion about this book. Its old edition and quite expensive. @otgnwp grab it from RedNectar if you can.
Happy learning!!
