12-02-2024 05:48 AM
Hello everyone!
I have a problem, periodically my APIC controller is lost on the ACI factory for about 15 minutes
At the same time, the controller also did not respond via mgm IP, although the port on the switch where it was connected was in UP
In this case we observe the following Fault code F0321
Screenshots are in the attachment
Thank you in advance
12-02-2024 11:18 PM
Hello @kz-support , please check the following diagnostics and troubleshooting steps:
12-28-2024 09:18 AM
thnx for your answer
I want to say that we did this command under admin privileges, but we didn't see the section that may be help us
acidiag cluster
Admin password:
Running...
Checking Wiring and UUID: Password Required!
Checking AD Processes: Running
Checking All Apics in Commission State: OK
Checking All Apics in Active State: OK
Checking Fabric Nodes: OK
Checking Apic Fully-Fit: OK
Checking Shard Convergence: Password Required!
Checking Leadership Degration: Optimal leader for all shards
Ping OOB IPs:
APIC-1: 10.1.151.53 - OK
APIC-2: 10.1.151.54 - OK
APIC-3: 10.1.151.55 - OK
Ping Infra IPs:
APIC-1: 172.1.0.1 - OK
APIC-2: 172.1.0.2 - OK
APIC-3: 172.1.0.3 - OK
Checking APIC Versions: Same (5.2(3g))
Checking SSL: OK
Full file system(s): None
Done!
