Question on using postman to configure a static vpc port binding
jgesualdi
I use postman in the following way to configure a static epg port binding, a vpc connection.
https://apic01/api/node/mo/uni/tn-tn_{{tenant}}/ap-ap_{{ap}}/epg-epg_{{epg}}_{{tenant}}.json
"fvRsPathAtt": {
"attributes": {
"encap": "vlan-{{epg}}",
"tDn": "topology/pod-1/protpaths-101-102/pathep-[fmdr-ucs-fi-a-p1-p2_PolGrp]",
"status": "created"
"children": []
This works but I need to run it twice for redundant devices. I was wondring if I could set two static ports binding in one post request.
Something that would look like this:
"fvRsPathAtt": {
"attributes": {
"tDn": "topology/pod-1/protpaths-101-102/pathep-[fmdr-ucs-fi-A-p1-p2_PolGrp]",
"tDn": "topology/pod-1/protpaths-101-102/pathep-[fmdr-ucs-fi-B-p3-p4_PolGrp]",
"status": "created"
"children": []
This obviously doesn't work.
Any suggestions?
Thanks.
Seb Rupik
Hi there,
Not sure about ACI, but from a programming perspective you have a datastrucutre with duplicate keys. Have you tried making the tDN key hold a list value:
  "fvRsPathAtt": {
    "attributes": {
      "tDn": ["topology/pod-1/protpaths-101-102/pathep-[fmdr-ucs-fi-A-p1-p2_PolGrp]",
        "topology/pod-1/protpaths-101-102/pathep-[fmdr-ucs-fi-B-p3-p4_PolGrp]"],
      "status": "created"
    "children": []
cheers,
Seb.
Claudia de Luna
Hi @jgesualdi,
I ran into something similar a while ago and used Postman Command or Collection Runner.
https://vimeo.com/385381561
Remi-Astruc
Hi @jgesualdi ,
Here it is...
https://apic01/api/node/mo/uni/tn-tn_{{tenant}}/ap-ap_{{ap}}.json
"fvAEPg": {
"attributes": {
"dn": "uni/tn-tn_{{tenant}}/ap-ap_{{ap}}/epg-epg_{{epg}}_{{tenant}}"
"children": [
"fvRsPathAtt": {
"attributes": {
"status": "created"
"fvRsPathAtt": {
"attributes": {
"status": "created"
Remi Astruc
rtmtoky
Hello @Remi-Astruc,
I have a similar question but it is not for APIC but  Nexus Dashboard Orchestrator API. Do you know by chance what’s wrong with my code?
Thank you in advance for your time.
