Question regarding Routing with two different L3 Outs / two FW Cluster
Torsten_Graf
Hello Community,
I have a question regarding routing with two l3 outs and two fw clusters.
as you can see we have a multi pod with a fw cluster in each pod (completely separate).
If VM B is trying to reach VM A (both in the same Datacenter, everything is working fine.
As soon as VM A is moved to the 2nd Datacenter, connection between VM A and VM B is not working anymore.
The way from VM B to VM A is still the same, but for the way back VM A is using the fw cluster in the 2nd DC as the default route is pointing towards this fw cluster.
Is there a way to get the VM A (when moved to 2nd DC) to use the L3Out in the 1st DC?
Best Regards
Torsten
AshSe
It's always good to prepares separate Physical and Logical Connectivity diagram to understand the query. Here I present your Logical Diagram. Please correct/Validate:
AshSe
....and I hope below is your Physical Connectivity diagram:
If this looks good, please feel free to present your requirement again.
Torsten_Graf
Hello AShSe.
thanks for your input. We have discussed with the customer and we will use inter VRF-Leaking as preferred solution.
We found a solution for the L3Out problem, but then we have some other problems.
Hello @Torsten_Graf  feel free to table your problem here in this forum.
