Bookmark
Subscribe
1154
Shutting down a leaf switch for DIMM replacement
AirBorn
Hello therr.
I'm planning to replace the DIMMs of an ACI fabric leaf switch
What is the safest way to do this. (Ie: shutting down the switch, replacing the DIMMs and bring it again into the fabric) The switch is in VPC group
ezong
Hi there,
To replace a DIMM, you can:
  1. Bring the leaf switch offline:
    Navigate to Fabric --> Inventory --> Fabric Membership --> target leaf --> right click --> Decommission
    After the above operation, the leaf will go into Inactive status.
  2. Wait for 10 minutes.
  3. Replace the DIMM.
  4. Bring the leaf switch back online.
    Navigate to Fabric --> Inventory --> Fabric Membership --> target leaf --> right click --> Commission
    After the above operation, the leaf will go into Active status.
Regarding VPC, you can refer to the steps in the section “Virtual Port Channel Migration" in the following document.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/hw/aci_hig/guide/b_aci_hardware_install_guide/b_aci_hardware_install_guide_chapter_011.html#id_97986
Cheers!
Eric
ezong
Hi there,
Cheers!
Eric
