simulator Cisco APIC
stefanodichio
I am trying to install a Cisco simulator V 5.2.7 (f) in a VM Ware esxi. The installation is successful, but i am no able to have connectivity to the APIC. I do not change any default config except the management IP/mask and default gateway IP.
Could you help me to find the issue.
Thank you.
Robert Burns
Did you configure the vSwitch Port Group with Promiscous Mode?
Robert
Ciao stefano
Only after adding additional 7 vNICs I would be able to access..... Why 7 additional? Well - after looking at the guide for the sim running on an UCS - so - I thought why not give it a try - wow - and suddenly it worked?
