Streched Bridge-domain and EPG between multisite without MSO
dijix1990
Can we stretched epg and bridge-domain between two sites without MSO
I have EP1 (10.10.1.100/24) on the site 1 and GW 10.10.1.1 on the site 1
I want to move EP2 from site 1 to site 2 with the same broadcast domain (10.10.1.0/24) but I didn't find any guide for implement it without MSO
RedNectar
Hi @dijix1990 ,
How are your two sites connected currently?
If you are using a Multi-pod design, or even a stretched fabric, you don't need to do anything - the same EPGs and BDs will exist at both sites.
BUT if you have two independent ACI fabrics, then to have EPs at both sites in the same EPG, you'll need to use Nexus Dashboard Orchestrator (the new name for MSO)
RedNectar aka Chris Welsh.
Oh it's pity. If I install NDO can I import all existed the tennant and BD/EPG to NDO from ACI? Or NDO create new tennant with new epg and bd?
Hi @dijix1990 ,
Once NDO is installed (not a simple task), you have an option to Import Tenants:
  1. In the left navigation menu, click Sites
  2. Locate the site from which you want to import the tenants, click its Actions ...) menu, and choose Import Tenants
  3. In the Import Tenants dialog, select one or more tenants to import and click Ok.
    The selected tenants will be imported into the Nexus Dashboard Orchestrator and show in the Application Management > Tenants page.
See this article for more info
