transit routing between two external ospf routers in same l3out on same borderleaf
csco10260962
What is the best way to do transit routing between two external ospf routers in same l3out on same borderleaf.
Routers are both in Area 0. One is part of old core network still advertising default gateway. Other router is advertising a lot of different external wan location networks and not easily tosummarize in supernets. ACI version 3.0
Would i set 0.0.0.0/1 and 128.0.0.0/1 as external subnets in epg. Enforce route import control on l3out and use 0.0.0.0/0 as route control import/export and aggregate summary import/export ?
Kind regards
PatrickH1
please find below a very good guide regarding "Transit Routing" in ACI.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/2-x/L3_config/b_Cisco_APIC_Layer_3_Configuration_Guide/b_Cisco_APIC_Layer_3_Configuration_Guide_chapter_010100.html
please find below a very good guide regarding "Best Practice Routing Design" in ACI.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/ACI_Best_Practices/b_ACI_Best_Practices/b_ACI_Best_Practices_chapter_010010.html
I hope this helps you, if yes, mark it as helpful :)
Kind Regards
Patrick
Thankyou,
I already knew about posted links.
Ans was more looking for sort of steb-by-step example from someone who already has this in place.
As there are not of exmples out there yet.
The best practices are great in description but sometime not very clear how to implement
