Why Does ACI Track Loose Nodes
Why does ACI track loose nodes?
Fabric > Inventory > Fabric Membership > Unmanged Fabric Nodes
What is ACI doing with these, that it needs to treate these devices with a level of magnificence greater than any other connected, non-fabric device?
weylin
Ruben Cocheno
@weylin.piegorsch
Unmanaged Fabric Nodes are devices that ACI detects via CDP/LLDP and create entries using their management IP address. It's not that it's detected as a Fabric Node, the name lets you know that it's not managed by the APIC. It's an outside device that ACI needs to be aware of.
In the case that you have a hypervisor behind those unmanaged devices, ACI should still be able to dynamically program VLANs as needed. This is the single hop away rule for VMM domains. It's the same if it was a blade switch chassis like a UCS Fabric Interconnect.
The only way to remove the unmanaged device would be either to unplug it from the fabric and wait a certain timeout period OR disable LLDP/CDP on the interface policy group related to the connected device.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
thanks @Ruben Cocheno .  Is it only for support to VMM Integration?  I'm not using that, but I can concede the point there.  What rules are used to decide whether a device gets listed as an unmanaged node?  It's clearly not simply that it's detected in CDP/LLDP, I have a plethora of devices that participate in discovery protocols but are not listed as unmanaged nodes.  And I have a number of nodes that, to me at least, clearly never could be VMM-managed (Dell switches; FWs; pre-UADP Catalysts; etc) but show up in the list.
